* Marte - Piramide D&M - particolare simmetria
News dal mondo dell'esobiologia
Nella medesima terra di "The Face of Mars" (Cydonia) è presente un altra conformazione veramente peculiare in quanto si presenta altamente simmetrica, ed in forma di pentagono.
Termna, in basso, a punta (triangolo rovesciato) a formare una figura romboidale, permeata da ulteriore simmetria.
CURIOSITA': una stretta analogia nelle proporzioni si ha con questo stemma (Europa in occasione euro)
Veramente impressionante :shock:
certo che è proprio strana come forma :roll:
Ecco una immagine a più alta risoluzione ripresa dalla MOC (Mars Orbiter Camera) installata a bordo della Mars Global Surveyor.
Ed ecco i dati della ripresa e delle elaborazioni:
CYDONIA OBSERVATION #3 PHOTO CAPTION
Orbit: 258
Range: 409.53 km
Resolution: 3.46 m/pixel
Image dimensions: 1024 X 9600 pixels, 3.5 km x 33.2 km
Line time: 0.50 msec
Emission angle: 29.90 degrees
Incidence angle: 69.59 degrees
Phase angle: 60.62 degrees
Scan rate: ~0.15 degree/sec
Start time: periapsis + 410 sec
Sequence submitted to JPL: Wed 04/22/98 21:45:00 PDT
Image acquired by MOC: Thu 04/23/98 12:23:02 PDT
Data retrieved from JPL: Fri 04/24/98 09:00 PDT
________________________________________
Processing Performed by Tim J. Parker, Geologist
Mars Pathfinder Science Support, JPL.
Image Processing Steps:
(1) Vertical banding in raw image removed using Vicar software with long,
narrow, highpass box filter, oriented parallel to banding in image.
(2) Performed moderate histogram stretch in Adobe Photoshop on
Macintosh desktop computer.
(3) "Flattened" broad shading variations in scene by
copying image and creating a "mask" in Photoshop with
the shading inverted with respect to the original image. This mask
was then merged with original scene and a second histogram stretch perf
Processing Performed by MIPL, JPL
(1) The image is sized down by interpolation by a factor of two to
reduce some of the noise.
(2) A long, narrow high-pass filter is applied in a vertical orientation
to help reduce some of the instrument signature. This signature is seen
as the streaking that is noticeable in the original data.
(3) A long, narrow low-pass filter is applied in a horizontal orientation
to create an intensity average for the image.
(4) The results of these filtering operations are the stretched to
approximate a Gaussian distribution.
(5) The results of the high-pass and low-pass processing steps are
averaged together to form the final product.
Immagino che sia tutto frutto della "natura Marziana". Certo le forme geometriche impressionano e fanno immaginare molto... Basta vedere le foto scattate all' esagono polare di Saturno.
E questa della donna su Marte l' avevate vista?
nintini
Residenza: Noci
Messaggio da nintini »
Pareidolia
Nicola Baruch
Immanuel Kant
Enzo, non andiamo fuori tema, please. Altrimenti se "scatena" er Nicola. :)
Paolo, grazie per il tuo apporto ma...
ATTENZIONE ! NON è la stessa collina. Come mai hai potuto errare? O te l'hanno suggerito i MIB? :) :)
Conosco questa formazione, vagamente pentagonale, sempre nella stessa area di Cydonia.
Ultima modifica di Riccardo Giuliani il mar ott 27, 2015 8:42 pm, modificato 1 volta in totale.
Giorni fa ricordo di aver letto un articolo il quale citava un link della Nasa che permetteva di partecipare ad un progetto collaborativo per poter esaminare le tantissime immagini ad alta definizione di Marte che la Nasa ha in archivio, ma non riesco piu' a trovarlo. Sarebbe una buona risorsa per eventuali ricerche di strutture geometriche su Marte. Se qualcuno ha traccia di tale link puo' postarlo.
Questo dato è molto importante. E' palese che qualcosa si sta muovendo (finalmente) nella giusta direzione.
Desidero rispondere a Nicola.
In merito al pianete Marte stanno emergendo innumerevoli casi (troppi) in merito a forme particolari.
Il termine "pareidolia" ci sta sempre più stretto... Sembra quasi che la NASA prediliga queste intrigantissime forme (probabilmente come test) o le "lasci passare".
nintini
Residenza: Noci
Caro Riccardo
Un pianeta é una cosa grande. C'è tanto spazio e tanta roba. Quindi molte probabilità di scorgere forme che appaiono familiari
Curiosity non ha trovato traccia di civiltà.
Piacerebbe anche a me avere evidenze di vita altrove. Ma non basta una montagna che appaia un po' regolare. O una roccia dalla forma curiosa e bizzarra.
Quando troveremo in manufatto gioirò insieme a te
Nicola Baruch
Immanuel Kant
Ti capisco Nicola, ma la gioia è sempre più vicina.
Mancherò per alcuni giorni, poi posterò proprio alcuni manufatti che hanno ben poco di pareidolia, sempre in tema di Marte. Intendo riprese generate dai robottini.
Il pianeta ha subito grandi cataclismi e fortissime erosioni nei millenni. Sabbia e forte vento tendono a levigare e coprire (quasi) tutto.
Effettivamente forse ho sbagliato a inserire l'immagine.
ecco quella corretta:
e il link all'immagine tiff a più alta risoluzione
http://photojournal.jpl.nasa.gov/tiff/PIA04745.tif
ripresa il 17/9/2003 dalla sonda Mars Global Surveyor.
hal9000
Residenza: Firenze
Messaggio da hal9000 »
Concordo al 100% con ogni parola e pure con la punteggiatura di quanto afferma Nicola nel suo ultimo post.
Pareidolia.... niente di più...... purtroppo.
Mr. Spock - Star Trek
Ragazzi finalmente ho ritrovato il sito di scienziati che chiedono aiuto nello studio delle immagini della sonda MRO che orbita intorno a Marte:
http://www.planetfour.org/#/home
Se non ho letto male il sito dispone di 4,771,068 immagini della sonda.
Quasi quasi mi iscrivo al progetto... :shock:
Re: * Marte - Piramide D&M - particolare simmetria
Riprendo la lista dopo anni.
Aggiornamento. Dopo un colloquio con Gabriele (mio figlio in quel di Londra) ho ricordato che, in archivio, avevo una foto (crop Hi-res) di una parte della piramide D&M con linee particolari.
In quest' area della suddetta zona collinare, ho notato dei solchi anche paralleli abbastanza interessanti.
Tra i due uno gira, quasi perfettamente, intorno ad un piccolo rilievo ovoidale.
Foto della stessa, ad altissima risoluzione > http://www.gigapan.com/galleries/13462/gigapans/190739
Che, in questi ambienti, spesso non aiuta. La sabbia, da millenni, copre e consuma ogni cosa.
Articolo su alcune formazioni anche in forma di piramide tetraedrica > https://www.tsijournals.com/articles/th ... chasma.pdf
Torna a “Vita altrove”
