La notizia non è nuova: l'ho trovata stasera, quasi per caso, in rete.
Ma fortemente autorevole.
https://www.ama-assn.org/ama-adopts-gui ... eet-lights
AMA Adopts Guidance to Reduce Harm from High Intensity Street Lights
For immediate release:
Jun 14, 2016
CHICAGO - Strong arguments exist for overhauling the lighting systems on U.S. roadways with light emitting diodes (LED), but conversions to improper LED technology can have adverse consequences. In response, physicians at the Annual Meeting of the American Medical Association (AMA) today adopted guidance for communities on selecting among LED lighting options to minimize potential harmful human and environmental effects.
Converting conventional street light to energy efficient LED lighting leads to cost and energy savings, and a lower reliance on fossil-based fuels. Approximately 10 percent of existing U.S. street lighting has been converted to solid state LED technology, with efforts underway to accelerate this conversion.
"Despite the energy efficiency benefits, some LED lights are harmful when used as street lighting," AMA Board Member Maya A. Babu, M.D., M.B.A. "The new AMA guidance encourages proper attention to optimal design and engineering features when converting to LED lighting that minimize detrimental health and environmental effects."
High-intensity LED lighting designs emit a large amount of blue light that appears white to the naked eye and create worse nighttime glare than conventional lighting. Discomfort and disability from intense, blue-rich LED lighting can decrease visual acuity and safety, resulting in concerns and creating a road hazard.
In addition to its impact on drivers, blue-rich LED streetlights operate at a wavelength that most adversely suppresses melatonin during night. It is estimated that white LED lamps have five times greater impact on circadian sleep rhythms than conventional street lamps. Recent large surveys found that brighter residential nighttime lighting is associated with reduced sleep times, dissatisfaction with sleep quality, excessive sleepiness, impaired daytime functioning and obesity.
The detrimental effects of high-intensity LED lighting are not limited to humans. Excessive outdoor lighting disrupts many species that need a dark environment. For instance, poorly designed LED lighting disorients some bird, insect, turtle and fish species, and U.S. national parks have adopted optimal lighting designs and practices that minimize the effects of light pollution on the environment.
Recognizing the detrimental effects of poorly-designed, high-intensity LED lighting, the AMA encourages communities to minimize and control blue-rich environmental lighting by using the lowest emission of blue light possible to reduce glare. The AMA recommends an intensity threshold for optimal LED lighting that minimizes blue-rich light. The AMA also recommends all LED lighting should be properly shielded to minimize glare and detrimental human health and environmental effects, and consideration should be given to utilize the ability of LED lighting to be dimmed for off-peak time periods.
The guidance adopted today by grassroots physicians who comprise the AMA's policy-making body strengthens the AMA's policy stand against light pollution and public awareness of the adverse health and environmental effects of pervasive nighttime lighting.
Media Contact:
AMA Media and Editorial
Pressroom: (312) 239-4991
Email: media@ama-assn.org
(traduzione maccheronica)
AMA adotta orientamenti per ridurre i danni dalle luci di strada ad alta intensità
- 14 giugno 2016
CHICAGO - Esistono forti argomenti per la revisione dei sistemi di illuminazione sulle strade statunitensi con i diodi emettitori di luce (LED), ma le conversioni a tecnologia LED improprio possono avere conseguenze negative. In risposta, i medici dell'Assemblea annuale dell'American Medical Association (AMA) hanno adottato oggi le linee guida per le comunità di scegliere tra le opzioni di illuminazione LED per ridurre al minimo i potenziali effetti nocivi umani e ambientali.
La trasformazione della luce stradale convenzionale a un'efficace illuminazione LED a basso consumo energetico porta a risparmi di costi e di energia e una minore dipendenza dai combustibili fossili. Circa il 10 per cento dell'attuale illuminazione stradale statunitense è stata convertita in tecnologia a LED a stato solido, con gli sforzi in corso per accelerare questa conversione.
"Nonostante i vantaggi dell'efficienza energetica, alcune luci a LED sono dannose quando utilizzate come illuminazione stradale", AMA Board Member Maya A. Babu, MD, MBA "La nuova guida AMA incoraggia un'attenzione adeguata al design ottimale e alle caratteristiche di ingegneria quando si converte in illuminazione LED che Minimizzare gli effetti negativi per la salute e gli effetti ambientali ".
I disegni di illuminazione a LED ad alta intensità emettono una grande quantità di luce blu che appare bianca a occhio nudo e crea un abbagliamento notturno peggiore rispetto all'illuminazione convenzionale. Il disagio e la disabilità da un'intensa illuminazione a LED ricca di azzurri possono ridurre l'acutezza visiva e la sicurezza, causando preoccupazioni e creare un rischio stradale.
Oltre al suo impatto sui conducenti, gli azzurri ricchi di azzurri LED funzionano ad una lunghezza d'onda che sopprime la melatonina durante la notte. Si stima che le lampade a LED bianchi abbiano cinque volte maggiore impatto sui ritmi sonori circadiani rispetto alle lampade stradali tradizionali. Recenti studi di grandi dimensioni hanno scoperto che l'illuminazione notturna più luminosa è associata a tempi di sonno ridotti, insoddisfazione per la qualità del sonno, eccessiva sonnolenza, alterazione del funzionamento del giorno e obesità.
Gli effetti negativi dell'illuminazione a LED ad alta intensità non sono limitati agli esseri umani. L'illuminazione esterna eccessiva distrugge molte specie che necessitano di un ambiente scuro. Per esempio, l'illuminazione LED a mal progettata disorienta alcune specie di uccelli, insetti, tartarughe e pesci, ei parchi nazionali degli Stati Uniti hanno adottato disegni e pratiche di illuminazione ottimali che riducono al minimo gli effetti dell'inquinamento luminoso sull'ambiente.
Riconoscendo gli effetti negativi dell'illuminazione a LED a basso intensità, AMA incoraggia le comunità a minimizzare e controllare l'illuminazione ambientale ricca di azzurro utilizzando l'emissione più bassa di azzurri possibili per ridurre l'abbagliamento. L'AMA raccomanda una soglia di intensità per un'illuminazione a LED ottimale che minimizza la luce ricca di azzurri. L'AMA raccomanda inoltre che tutte le luci a LED debbano essere correttamente schermate per ridurre al minimo il bagliore e gli effetti della salute umana e degli effetti ambientali, e si dovrebbe considerare di utilizzare la capacità dell'illuminazione LED di essere disattivata per periodi di scadenza.
Le linee guida adottate oggi dai medici di base che compongono il corpo politico della AMA rafforzano la posizione politica di AMA contro l'inquinamento luminoso e la consapevolezza pubblica degli effetti negativi sulla salute e sugli effetti ambientali di una diffusa illuminazione notturna.
p.s = è consigliabile, almeno, adottare LED a "luce calda", meno dannosi di quelli a luce fredda.
* AMA > American Medical Association - i Led sono dannosi
- Mimmo Antares
- Residenza: Polignano a mare
